INDUSTRY-STANDARD SCANNER DRIVERS AND IMAGING TOOLKITS
WATCH VIDEO
OpenText Documentum Webtop: Browser-based interface that provides access to the OpenText Documentum repository and enterprise content management services.
MORE CONTROL
Unlike the TWAIN standard, ISIS, and PixTools and Captiva Cloud Toolkit allow developers complete control over the user experience, including features such as scan, display, file writing, and printing – just three of the many functions that cannot be controlled using TWAIN.
MORE FLEXIBILITY
Rapidly develop capture solutions or enhance existing applications with imaging capabilities—including zero foot-print scanning and web-based imaging functionality—that reliably communicate with hundreds of scanners using ISIS and TWAIN.
MORE SUPPORT
Gain greater support than TWAIN, ISIS and PixTools provide. More consistent support for more than 400 ISIS-compatible scanners. Your applications work more reliably and you won’t need to test and develop each new scanner individually.
VIEW DATASHEET
